recon motor conversion
Old May 28, 2002 | 11:08 PM
reconbasher's Avatar
About a month ago my recon sort of sever caught a case of the $hits, and the motor went into peices inside. I was wondering if a 250ex motor would bolt right up to it since they are the same engines but differnt carbs. And what the price diffence would be between them.
P.S. i do have a welder and plasma cutter to do the mods to the mounting process that is needed.
Old May 28, 2002 | 11:24 PM
ex_master's Avatar
Same motor , Same frame , it'll work.
Old May 29, 2002 | 12:13 AM
yaright's Avatar
they aren't exactly the same on the inside unless you have a 2002 recon, because they switched to using the same exact motors, but on the outside a 250ex motor is exactly the same as the outside of any year of recon motor
Old May 29, 2002 | 12:14 AM
KNOWSALOT's Avatar
The Facility
Yes..it will work, but the cost of a new engine is nearly $3000.00!!
You would be better off at fixing your Recon or selling it for scrap and just buy a new 20EX.
Old May 29, 2002 | 08:41 PM
i have a 1999 model what woud be different inside the motor as far as everything bolting up and my driveshaft hooking up inside?
fd24
Jan 16, 2019 08:59 AM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
Jason Campbell
Sep 7, 2015 02:25 PM
