ATC 250r sprocket ?
Old May 28, 2002 | 11:38 PM
Fullbore's Avatar
I was wondering what size front sprocket is recommended when running 20's. 13 or 14? Thanks in advance
Old May 29, 2002 | 03:01 PM
retro's Avatar
The stock 86/87 had 13/39 gearing and the 88/89's had 13/38.
A 14 tooth on the front with 20's would go about 80!
ERIC
Old May 29, 2002 | 05:26 PM
atc86r's Avatar
what kind of riding and where. when i was stock i would go down 1 tooth when using paddles.
Old May 30, 2002 | 01:08 AM
kciH's Avatar
I've got a 15/36 combo for my big bore ATC350Rpv. I'll let you know how it works out in the next couple of weeks. I might throw some 22 inch tires on the back and see if it will go 100!
The stock gearing on your machine would be a 13/39. If you are going to run 20 inch tires, which happen to be the stock size, I would stay with that. If you're running sand drop 1 tooth off the front or 3 off the rear. The 1 tooth off the front will cost you a lot less and will likely not affect the narrow range of chain adjustment as much. If your current sprockets are hatched, remember that a new chain and sprockets replaced as a set usually give you much more life if properly maintained. Also, even the cheapest $40 Oring chain will outlast the best non-oring chain(unless you remove it after every ride and soak it in oil, which is a PintheA and not worth time).
Happy roosting [img]i/expressions/face-icon-small-smile.gif[/img]
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
