ATC 250r sprocket ?
I've got a 15/36 combo for my big bore ATC350Rpv. I'll let you know how it works out in the next couple of weeks. I might throw some 22 inch tires on the back and see if it will go 100!
The stock gearing on your machine would be a 13/39. If you are going to run 20 inch tires, which happen to be the stock size, I would stay with that. If you're running sand drop 1 tooth off the front or 3 off the rear. The 1 tooth off the front will cost you a lot less and will likely not affect the narrow range of chain adjustment as much. If your current sprockets are hatched, remember that a new chain and sprockets replaced as a set usually give you much more life if properly maintained. Also, even the cheapest $40 Oring chain will outlast the best non-oring chain(unless you remove it after every ride and soak it in oil, which is a PintheA and not worth time).
Happy roosting [img]i/expressions/face-icon-small-smile.gif[/img]
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
