NoS Timing Help
Old Jun 13, 2002 | 03:02 AM
DsDude's Avatar
I just bought a NOS kit from RWR.
Did any of you guys that installed NOS on your DS650 adjust the timing? Nos Tech support told me to retard it 2 deg. Eliot at Ron Woods Racing said to run it the way it is. What should I do?
Can you guys tell me the best place to install the bottle?
I don't want to remove the air box,and I have a PeP sreering dampner up front
Pictures would be nice.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 13, 2002 | 10:36 AM
DsDude's Avatar
Here is the spot I was thinking about. I think this won't work because the bottle is not in the right position. What do you guys think?
Click Here to See Picture
Old Jun 13, 2002 | 11:25 AM
jeffnrivercity's Avatar
DsDude,
Your bottle does need to be on an angle,it will work like that but you wont get all the N20 that is available.It would suck having to change bottles every couple of runs.
AZSAND has his on the rear grab bar............
Old Jun 13, 2002 | 11:42 AM
DsDude's Avatar
Can you tell me the approximate angle?
AZSAND are you out there? Do you have any pictures I can look at?
Thanks
Old Jun 13, 2002 | 12:33 PM
NOS bottles come with siphon tubes and, in order to maintain proper nitrous pickup, it is important to mount the bottle correctly. Recommend mounting of the bottle is at a 15 degree angle with the valve end higher than the bottom of the bottle.The valve **** and label should face straight up.
Jeff
Old Jun 13, 2002 | 01:03 PM
DsDude's Avatar
Thanks jeffnrivercity for the Info
Old Jun 13, 2002 | 09:22 PM
badassbomb's Avatar
i have mine on my rear grab bar also.. how do i post a pic?
Old Jun 13, 2002 | 10:28 PM
DsDude's Avatar
jeffnrivercity,
What do yo think about this mount configuration?
Click here
Old Jun 13, 2002 | 10:43 PM
DemonDS's Avatar
Well I am not Jeff but I could see a few problems withit. First from that angle it looks as if you would be blocking much air flow to your radiator. Second it looks like you would only be able to use on mounting ring. That may be enough, I dont know but I would use two rings. Just curious as to why you want to keep that power robbing Air box? Those look like some sweet nerf bars, could you throw up a pic or a link of them and the heel guards? Looks like a nice DS!
Old Jun 13, 2002 | 10:53 PM
badassbomb's Avatar
ok i sent you 2 pics of my DS with my nos mounted on my grab bar
