Stock BSR42mm Carb
Old Jun 13, 2002 | 11:06 PM
AdamsBadDS650's Avatar
Ok, I'm going to try to do this without upseting the moderators.
Ok, I took the screws out of the float bowl, which was a big pain, and took them to the hardware store, and told them to match them with allen head ones for me. I left, then picked them up later. When I put them in, I think they got the thread size a little too small, and I think I stripped the threads on the carb.
So does anyone know where I could find a clean used stock BSR42mm carb, for very little, or better yet, a TM45mm carb. Please Pm me if you know where to get one.
Old Jun 13, 2002 | 11:22 PM
VEGAS650's Avatar
Done.
I have both. Stock is a thumb throttle. 45 is a twist.
Old Jun 13, 2002 | 11:55 PM
Yeah, I'd rather have a thumb throttle, sorry Josh. Is there a way to turn a twist carb into a thumb throttle carb? Anyone know?
Old Jun 14, 2002 | 12:20 AM
sand45's Avatar
ya ron woods should have everything you need!all but the stock thumb throttle.
Old Jun 14, 2002 | 01:01 AM
Hightower's Avatar
Don't replace the carb just because of some stripped threads - retap the holes the next size up. They are metric, but you can probably go with an inch screw that is only slightly larger than the original metric, without taking a whole step up in metric size.
The hardware store probably gave you inch screws instead of metric. Hopefully, you only stripped one and stopped there.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
