Scrambler tranny
Old Jun 16, 2002 | 04:11 PM
MattDewalt's Avatar
I recently got a 99 Scrambler 400 4x4. I love everything about it except for one thing. When going down hills, the transmission does not gear down. If you're off the gas, the only way to slow down is to use the brakes. Is this normal? Would a clutch kit help this? Anything else that would cure this problem? I'm used to having gears and being able to downshift to slow me down. I test drove an 02 Scrambler 500 4x4, and from what I remember, it seemd to gear down when you let off the throttle.
Old Jun 16, 2002 | 09:04 PM
ftwflh's Avatar
Welcome to the world of Polaris!All you can do is learn to love it the way it is or you can put in an EBS system for about $500 or you can change secondary springs that let it back shift differant.I used a blue Aaen secondary spring and it helped a little.
Old Jun 16, 2002 | 10:29 PM
Ronnnnn's Avatar
Check out HPD's new catalog, they have a new clutch from a company called team something, the version with the engine braking really does work, a guy from here moto crosses a HPD frame quad with that clutch in it. doesnt need to use the brakes.
Old Jun 16, 2002 | 10:42 PM
PolarisPower500's Avatar
You can slow the Scrambler down by barely giving it gas. This will cause the clutch to grab the belt and the engine will then hold the quad from going any faster. If you don't touch the throttle, the tranny and tires will free spin and go faster and faster.
Old Jun 17, 2002 | 12:02 PM
KEP's Avatar
KEP
I have noticed the same thing PolarisPower500 talked about, keping the belts engaged by giving it a little throttle every now and then. And yes, you can put the EBS kit on it or maybe mess with springs, but before you spend a lot of money on all that, keep in mind that replacing brake pads occasionally is relatively cheap in comparison.
Old Jun 17, 2002 | 01:11 PM
MattDewalt's Avatar
I've tried hitting the throttle a little - it doesn't seem to help. Maybe I have some weak springs. I was kind of hesitant on using the brakes. When I go down steep hills, I used to shift into a low gear and let the engine pull me down and I'd hit the rear brake as needed to slow me down. With the Polaris single brake system, I thought it may lock the front up too much going down hills. That's why I was looking for some engine braking. How does the Polaris brake setup work on hills? Does it transfer the power to the rear wheels when going down hills and the front wheels if you need to stop going up a hill? Again, I really love this quad compared to my Wolverine - the handling and power is superb. If I could work out the braking and downshifting, it would be the ultimate machine for me.
Old Jun 17, 2002 | 07:50 PM
modquad's Avatar
Go with an EBS or roller setup. I can run the trails at 50mph and get over a year out of brake pads. Instant backshift is a great addition. The Team series clutches are available at HPD and Hot Seat. These two with the addition of Aaen offer roller clutches.
Ken
Old Jun 17, 2002 | 07:56 PM
ftwflh's Avatar
Try the Blue Aaen secondary spring befor you put out big bucks on an EBS.And learn to use the brakes going down hills.It is scary at first but you will get the hang of it.
Old Jun 17, 2002 | 09:15 PM
dillas23's Avatar
If you are worried about the brakes why not buy the option that lets you spit your brakes. That way you won't be afraid to just use the rear brakes when going down hills
Old Jun 18, 2002 | 02:41 AM
ftwflh's Avatar
BLUE AAEN SECONDARY SPRING SET AT 2 AND 2
