Cheap power increases??? for the DS
Ok,
I dont have boat loads of money to spend as the wife says... So, what is the minimum I can spend to make the most differance? 15t srproket? CDI box? K&N with jets? like the wife says lose weight!! JK... no for real, what can I do that dont cost a boat load.....
Yes! it dose make a diff. All i did was pulled the end cap of then took the spark arrester off then cut the two inlet flush with the end cap. Then there is little screens in side the 2 inlets pull those off to and put your cap back on and rejet your carb. Thats the way i did it but do a search on end caps there is alot of info on it and diffrent ways to do it too!
Aug 11, 2015 11:56 PM
