Cheap power increases??? for the DS
Old Jun 18, 2002 | 12:17 AM
MudStud's Avatar
Ok,
I dont have boat loads of money to spend as the wife says... So, what is the minimum I can spend to make the most differance? 15t srproket? CDI box? K&N with jets? like the wife says lose weight!! JK... no for real, what can I do that dont cost a boat load.....
Old Jun 18, 2002 | 12:47 AM
sand45's Avatar
My wife tells me the samething about losing weight!(LOL)I think best mods for the money is mod your end cap...K&N filter and jet kit, you may not whant the 15 tooth sprocket if you mod your end cap.
Old Jun 18, 2002 | 12:54 AM
MudStud's Avatar
How do i mod the end cap? does it make a differance?
Old Jun 18, 2002 | 01:02 AM
sand45's Avatar
Yes! it dose make a diff. All i did was pulled the end cap of then took the spark arrester off then cut the two inlet flush with the end cap. Then there is little screens in side the 2 inlets pull those off to and put your cap back on and rejet your carb. Thats the way i did it but do a search on end caps there is alot of info on it and diffrent ways to do it too!
Bratman2
Aug 6, 2022 01:42 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Aug 11, 2015 11:56 PM
Jul 23, 2015 07:53 AM
