97 Trailblazer cylinder removal
Old Jun 21, 2002 | 03:43 PM
scramblazer400's Avatar
Hi
Im tring to find out what is the best way to remove the cylinder.
remove eng and trans or try doing this on the quad
Old Jun 21, 2002 | 05:04 PM
400fnSport's Avatar
I've done this numerous times on my Sport. It's quite simple. No need to remove the trans or engine. Just remove your front plastic off your quad. And then remove your gas tank. From there unmount the top engine bracket, carb, intake boot, and exhaust. Then all you need to do is unbolt the 4 bolts holding the cylinder on. Then the cylinder will slid right off. You may also want to go ahead and remove your head off the cylinder before pulling it off. I've done it so much I could tell you every bolt size that's on it, and have it off in about 10-15 minutes.
Old Jun 21, 2002 | 05:23 PM
williewonka71's Avatar
take off the fuel tank and do it in the frame.
neo27ny
May 14, 2018 12:19 PM
Cantbuytime
Aug 16, 2015 09:13 PM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
Sandman2.0
Jul 21, 2015 09:03 AM
shewshew989
Jul 14, 2015 03:09 AM
