What to torqe clutch bolts to for a 400?
Old Jun 23, 2002 | 12:56 AM
RdingManiac420's Avatar
I am putting a clutch in for my friend and I need to know what to spec the 5 bolts that hold the plates in the basket to. Someone please give me a hand!!
Old Jun 24, 2002 | 11:56 AM
CBUS660R's Avatar
You just snug them down. Don't crank on em, they will break. Probably in the 10# range or less. I broke one on my R, couldn't find any specs, so I tried 20# and it spun the head right off before the torque wrench "clicked"
Old Jun 25, 2002 | 07:59 AM
DS650DAVE's Avatar
5-7 lbs should be ok ..
Old Jun 25, 2002 | 02:50 PM
prang11's Avatar
I also broke one off in my new clutch. Just snug them till they stop spinning dont even use a torque wrench. If you think you need to give them another turn DONT.
Old Jun 26, 2002 | 02:02 AM
maxxpwr's Avatar
i looked in my service manual and it doesn't give the specs for those particular bolts. the manual does give specs for the different size bols found on the bike. here they are as writen in the manual. (note that the size, in millimeters, is measured at the shank of the bolt not at the bolts head.)
5mm bolt and nut 3.6 lbf-ft
6mm bolt and nut 7 lbf-ft
8mm bolt and nut 16 lbf-ft
10mm bolt and nut 25 lbf-ft
12mm bolt and nut 40 lbf-ft
6mm flange bolt (8mm head, small flange) 6.5 lbf-ft
6mm flange bolt (8mm head, large flange) 9 lbf-ft
6mm flange bolt (10mm head) and nut 9 lbf-ft
8mm flange bolt and nut 20 lbf-ft
10mm flange bolt and nut 29 lbf-ft
in the breakdown drawing of the clutch the bolt appears to be the "6mm bolt and nut". i hope that was some help.
Steeldon
Sep 9, 2015 09:38 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
