Another Question for NYROC
Old Jun 23, 2002 | 03:11 PM
kawikentuckian650's Avatar
How's it going, are you mended yet... Anyway when you rejetted your carbs did you replace the pilot jets (one with notches) with ones from kit or did you use factory ones. I'm getting ready to order kit and was wondering how many jets you actually replace:
2 mains, 2 pilots(needles) I know u use 130, 134 mains, what was size of factories. Did you try different combinations and come to conclusion that the 130, 134 was the very best? (oh and pilot in 4th notch)
I looked on epi, they have clutch kits, u get 2 springs, didn't actually see a black one. Do you have these, and would they actually improve low/mid end enough where u could really tell a difference.
(YES I AM FINISHED !!) and thanks for your previous speedy replys
Old Jun 23, 2002 | 03:27 PM
STAKK's Avatar
Roc amy back me on this, the pilot's and needle's are diferent jets altogeher.they do not change the pilot jet's at all you adjust the air/fuel mixture screw's use their needle's with the notch's and use their main's.the stock jet's should be a 138 in the front and 142 in the rear, I jetted mine when the kit's first came out and by trial and error found that the main jet recommendation's they say are pretty close but using the needles in the 5th notch just does not work well, useing the 4th notch and then going by the instruction's on the main's and screw setting's will be very close if not right on the money......
Old Jun 23, 2002 | 03:29 PM
STAKK's Avatar
SORRY! got in a hurry,ment to say Roc "may" back me, was not calling him Roc Amy... Who said I could type anyway?
Old Jun 23, 2002 | 03:34 PM
So I will be actually replacing my mains, and needles, and not the pilot. I read where NYROC used 130 and 134's and he had good luck with this. I may try your recomendation also. Did you find your gas mileage went down hill drastically or not that bad..
Thanks for the reply... James
Old Jun 23, 2002 | 03:36 PM
forgot to ask stakk, good increase on low-mid end, did pipe mod like NYROC's still can't get rid of backfire, hoping these adjustment and kit will help
Old Jun 23, 2002 | 03:53 PM
nyroc's Avatar
Kawikentukian what Stakk said is right, I originally learned about rejetting my 650 from Stakk anyway.
I am as good as new now. No more pain, just yellow and purple spots.
Backfire? I don't remember if it was you I told, but lean idle causes backfire, and also leaking exhaust system. Another thing you need to pay careful attention to is that any motorcycle with an open enough pipe will blurble a bit. But, since you are describing a backfire, I would suspect either a leak or lean idle. I have heard a stock 660 backfire a few times just because we rode it 2000ft higher than where it was jetted to be run. My 650 pretty much does not backfire, but it backfired a few times at the elevation that the 660 backfired.
Here is some text that someone else found and posted earlier:
Backfires in Exhaust.
Note:
It is normal for many high performance exhaust systems to moderately backfire or pop when the throttle is closed from mid-to-high rpm. In fact, one should expect a well-tuned high performance engine to "pop" and "crackle" when the throttle is closed at high rpm.
The popping is a result of the air/fuel mixture becoming very lean when the throttle is closed and the engine is rotating well above idle speed. It is also necessary that the exhaust system have rather open mufflers for this to occur.
Why This (normally) Happens:
1) When the throttle valve is in the idle position, fuel does not flow out of the main system (needle, needle jet, main jet). Fuel is only delivered to the engine by the pilot (idle) system.
2) The combined effect of the closed throttle and elevated engine rpm is to create a fairly strong vacuum in the intake manifold. This vacuum, in turn, causes a high air flow rate through the small gap formed by the throttle valve and carburetor throat.
3) Under these conditions the pilot (idle) system cannot deliver enough fuel to create a normal, combustible air/fuel ratio. The mixture becomes too lean to burn reliably in the combustion chamber. It gets sent into the exhaust system unburned and collects there.
4) When the odd firing of the lean mixture does occur, it is sent, still burning, into the exhaust system where it sometimes ignites the raw mixture that has collected ---- the exhaust then pops or backfires
Other possible causes:
Air Leaks:
Any source of fresh air into the exhaust system can create or worsen the conditions that bring about exhaust popping. The most common entry point is the junction of the header pipes and mufflers. Even a small air leak can dramatically increase the intensity or likelihood of exhaust system popping.
A high temperature silicone sealant, as can be found in many auto parts stores, may be used to seal the pipe/muffler junction.
Lean Carburetion:
While exhaust system popping may be considered normal, it is certainly made worse by an overly lean idle circuit.
Be sure that your carburetor's pilot jet is the correct size and that the idle air mixture screw is correctly adjusted before looking for other causes of popping. The procedure for adjusting the pilot circuit is covered in the Tuning Manual.
Ignition:
If exhaust system popping is very loud, irregular and accompanied by loss of power, then you should suspect that the ignition system is not performing as it should. If, for some reason, the ignition sometimes fires at the wrong time, then exhaust popping can become very energetic (loud). Look for failing high tension leads (plug wires), failing ignition coil(s) and especially switches or connectors as possible causes.
I keep info such as this (that I consider valuable and difficult to find) in a area of my website so I can quickly grab it and spew it back out. I do not believe the 650 ignition is capable of causing what you describe. Hope this helps.
Old Jun 23, 2002 | 05:18 PM
STAKK's Avatar
If you have done the muff. mod and any air box mod, then go ahead and use the 130/134 mains, but put the needle's in the 4th notch instead of the 5th, back the air screws out 3 full turns, this should fix the backfireing problem,also if it is a little rich or lean depending on the elevation you live and heat/humidity, then you can go up or down on just the main's to straighten it out. I now run a Bigger snorkel(NAPA rad.hose) 5 uni-vents in the lid, Twin Air filter,HMF,dyno-jet with air screw's 3 turns out,needle's 4th notch, and 136 main front carb,140 main rear carb. I had to order the bigger main's from dyno-jet, they did not have the 140 in the kit.but unless you really increase the air like I have you won't have to go as big on the mains, My gas milage has actally increased quite a bit, I can now ride about 21 miles before I use 1 bar of gas on the gauge,also I have filled my tank from dry, and it held 4.923 gal. instead of 4.5 like they say,when all is said and done and you get your jetting right, not to rich, and God forbid not to lean, you'll have a good deal more power, and should have better gas mileage too.......
Old Jun 23, 2002 | 11:45 PM
alltoys's Avatar
Stakk
I have done the mods that Nyroc suggested only drilled 7 1/2in holes and cut out the baffle. I also put in dyno flows suggested jets at the 5th notch and not the 4th like you say. Performance was substandard just slighty over stock without mods. With muffler done and stock jets the power band improved 10.35% this is at 2200ft with 28 in Outlaws. I gained more torque and slightly more speed in a running mile. I went from 65km/hr to 70km/hr in the mile. I now of the power band as my dealer has a dyno. I went to dyno flows jet setting and the 5th notch and the power only improved a dismal 3.23% hardly worth getting up early for. You say the 4th is vastly improved over the 5th, I will try this later this week and let you all now how it turned out. Although the stock jets worked very well and if this the 4th notch doen't improve it I will return to stock.
I Master Blaster sent me a site with a picture of Bearman's intake snorkel and I can tell you it is well worth the look and most all the price.
Stakk would you suggest the larger jets with this update from diamondG. When I finish with the mods I will let you all now how things turn out.
Keep the sunny side up now.
Old Jun 24, 2002 | 12:33 PM
STAKK's Avatar
The first thing to do is use dyno-jet needle's and dyno-jet main jet's together,their needle's and stock jets won't work well together. with the baffle out and more air coming in even at 2800 you may be lean, depend's on the bike.I have found that useing the airscrew's at 3 turn's out, and putting the needle's in the 4th notch,makes the jetting process more simple because you won't have to touch them again, only the main's from there on,bigger or smaller main's willpretty much get you there,try the 4th notch and leave it alone after that then just try diff. mains.put the biggest you got in the kit,I think it should be 134 front,138 rear. Then ride at diff, throttle positions,if it stumbles when you crack it wide open from about 1/4 throttle to wide open drop one size at a time until it clears up,I'm betting these jets or the 132/136 will be it.The dyno's are funny,they may show the most horsepower with a certain jet but the quad may actually RUN better with another,go by how fast the quad feels and times by the stopwatch,be careful to, a motor always makes the most power on a dyno when it is really lean,sometimes on the borderline of meltdown,You are on the right track these jet kit's will only do so much, give you better throttle response,but won't make huge gain's in power like a cam and bore job, to get the most out of a Stock engine you must do an aftermarket exhaust,filter,jet kit, valve adjust,carb sync.when these are all added together and the quad is in perfect tune,you can expect a good power increase then, with the jet kit alone and what you have done, about 5-6% increase is a good improvement.....
Old Jun 24, 2002 | 12:38 PM
monteSS's Avatar
Nyroc did you use the spacers when you had it in the forth notch? I put them in like Dyno Jet said that could be a little of my problem too[img]i/expressions/face-icon-small-smile.gif[/img]
