rubi owners
Old Jun 24, 2002 | 09:17 PM
Beerpuker's Avatar
two weeks ago i was mudding at the badlands and my machine started to overheat. i shut it down for the day. came home washed it and flushed all the mud out of the radiator fins and gave it a go this past weekend. and not two hours of just trail riding it started to overheat again. needless to say it cut my day short. anyone have any ideas of why my machine might be overheating? thanks for the advise ahead of time.
Jim [img]i/expressions/face-icon-small-frown.gif[/img]
Old Jun 24, 2002 | 10:53 PM
plunker's Avatar
Check and see if the fan is coming on! My rad looked clean and it really wasn't till I removed the plastic radiator protector directly in front of the rad and flushed a lot of water through it.
Old Jun 24, 2002 | 11:16 PM
rubiowner01's Avatar
I had this same problem. Try removing the black plate and clean the radiator out completely. The way i did this was to take a spray bottle and put hot water and some 409 in it. I sprayed about 2 full bottles of the mixture and it cleaned it up real good. Have not had an overheating problem since. Also you might try and check your coolant. Hope this helps.
Old Jun 25, 2002 | 09:58 PM
Beerpuker's Avatar
thanks for the info guys. i will give that a try.
Jim
Old Jun 25, 2002 | 11:42 PM
Tell us what you find out.
Old Jun 28, 2002 | 07:04 PM
Beerpuker's Avatar
well it ended up being clogged with mud. i took it in the the dealer to get a tune up and had them look at it and they said it was packed with mud. i am going to the badlands on the 13th, so i will find out if that was actually the problem. thanks for your info
Jim [img]i/expressions/face-icon-small-smile.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
