no spark???
Old Jun 24, 2002 | 11:16 PM
warrior350megamax's Avatar
ok, if anyone read my latest post it was that i couldn't get my engine to start, now i figured out it's that i have no spark (in case youre wondering i just changed the spark plug), so what could it be? list any little possibility, also could it be that my battery pretty much dead? any info appreciated,
warrior350megamax
Old Jun 24, 2002 | 11:23 PM
desracers's Avatar
Does the engine turn over? If so then battery is okay. If not then replace the battery.
If the engine turn over with battery ok. You might have plug wire have gone bad,cap? Coil might gone bad too.
It could be the cdi went bad. There are lot of things why you are not getting spark.
so just take one things at a time and have a friend of your to help you out....
Or just take it to the shop....
Old Jun 24, 2002 | 11:31 PM
im going to be spending alot of tommorrow checking all the ideas i get but if this helps it ran fin 2 weeks ago but i couldnt drive due to a broken tie rod end so after i parked it, it just sat there, i don't know. my battery does turn over by the way, thanks again
warrior350megamax
Old Jun 24, 2002 | 11:36 PM
desracers's Avatar
I would check the plug wire since you mention of the tie rods. Did it broke while you were riding it? That would be my first thing to check it out....
Also give us more infor before it happen and after. that way somebody might have an answer for you.
Old Jun 24, 2002 | 11:47 PM
2fat4moto's Avatar
I don't know about your bike, but the Blaster has some kind of electrical deal on top of the carb. Seems if this screw comes loose, no fire! If it has this, check to be sure it is screwed in all the way!
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
