FMF vs WB
Old Jun 25, 2002 | 09:40 PM
mojavekid13's Avatar
I just ant to know what u goys though about bouth these pipes???Witch one would u get???i know alot of u are going to say get the IDS2,well i already have it,this is for my dad,And he doesent have the $$$$$$$$$$ to get the IDS2 ,so witch on would u get????Witch one is better on botomend??thanks guys
Old Jun 25, 2002 | 11:33 PM
bigbad400's Avatar
I like the WB my self pretty good.
Old Jun 25, 2002 | 11:48 PM
MOJAVE02's Avatar
go with a white bros. it sounds great and gives tons more power over stock!!
Old Jun 26, 2002 | 12:32 AM
mentalmojave's Avatar
If you want good bottom-mid power I think the white bros is the better bet. It is designed for low-mid power. I will be switching to an ids race core since it is made for mid-top power and thats what I need with my cams.
Old Jun 26, 2002 | 07:15 AM
I already have a K&N clamp on filter,and i plan on running 12disk on my pipe.One more question??How many disk does the pipe come with and did any of u need to re-jet or Buy one of those heat sheilds???thanks
Old Jun 26, 2002 | 11:30 AM
MOJAVE02's Avatar
the white bros comes with 12 discs from whatever company you order it. no you don't have to rejet for just the pipe, but you will have to rejet for the pipe and clamp on filter. but definetly go with the white bros, you won't be sorry and it also sounds great!
Old Jun 26, 2002 | 12:31 PM
So the best combo is 12 disk with the clamp on filter,what will i have to change my main jet to??
Old Jun 27, 2002 | 12:19 AM
mojavez400's Avatar
i like my FMF Megamax Pipe it increases Low end alot. It is very loud without the QUiet core or the discs. You reallly need to have both on otherwise it is way noisy. But if you want performance take all of the plates off and watch it fly.
Old Jun 27, 2002 | 12:52 AM
MOJAVE02's Avatar
i dont know what the jetting spec will be with the clamp on filter. but using a K&N filter (w/stock airbox) and the wb pipe i am running a DJ134 main jet, and the needle clip on the 3rd position. also the air mixture screw 1-1/2 or 2 turns out. hope this helps.
Mark
Old Jun 27, 2002 | 09:21 AM
Mojavez400
Did u have to re-jet with the FMF???? Did it give u good bottom end???Becaus ethet is what iam looking fo r,is bottom end noting else!!
