Engine Ice or Redline Water Wetter??????
Old Jun 26, 2002 | 04:10 PM
alljuice's Avatar
What is better?
Old Jun 26, 2002 | 06:59 PM
AZDUNNER's Avatar
I was using Redline for about a year but decided to switch to Engine Ice. My reasoning was that Engine Ice has to potential to operate at lower temps due to it's properties (up to 50 degrees F in some cases). A cooler running engine will last longer and the oil won't break down as quickly.
When using Red Line my fan would come on more than I liked. I noticed a difference using Engine Ice, as the fan almost never comes on now.
Here's the rub: When switching to Engine Ice you have to make sure all your old coolant is removed from the engine. If you don't, the Engine Ice (Polypropylene based) will react with the standard coolant (Ethylene Glycol based) and cause gelling.
I purchased about 5 gal. of DI water and flushed my engine a dozen times to make sure all my old coolant was gone. I drained, filled w/ DI, ran for 5 minutes, drained, filled, ran for five minutes, etc., etc., etc.
The Engine Ice is a little costly but I think it's worth it. One gallon should more than fill your quad. Also, you run it straight, i.e.; you don't dilute it.
Old Jun 26, 2002 | 08:58 PM
desracers's Avatar
Hey AZdunner
Where would I able to pick up Engine ice? Motorcycle shops or 4x4 shops?
Old Jun 27, 2002 | 02:34 PM
AZDUNNER's Avatar
Here's the Web address and the list of distributors that are listed on it.
http://www.cyclelogic.cc/
Branch Marketing (562) 235-3603
Louisiana Chip Carrie (337) 739-9255
New Mexico Cheyenne Cycle Supply 800-275-1167
Kentucky Sayco Racing Products (606) 521-5815
Arizona BT Performance (480) 834-5753
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
ltrmc02
Jul 22, 2015 04:50 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
