Cam Installation+Info
Old Jul 1, 2002 | 11:22 PM
MOJAVE02's Avatar
i am looking into buying white bros cams(all around)+ valve springs, and also get the rev limiter removed. my mojave is piped, filtered, and jetted(134 main). will i have to make any jetting changes to run this new setup? also how will the machine compare against a 400ex and warrior on trails and in drags? what will the top speed be increased to as well?
Old Jul 2, 2002 | 12:01 AM
2fat4moto's Avatar
WARNING! If you install rpm cams to replace torgue cams you will loose midrange. This is what you mostly use unless you are riding the quad wide open. Think about this before you come off the money. If you wanted a sport bike, then.....
Old Jul 2, 2002 | 02:56 PM
MOJAVE02's Avatar
thanks, but if I put on the all around cams would i really loose that much torque?
Old Jul 2, 2002 | 07:26 PM
2fat4moto's Avatar
HMMMM, You got me there. Sounds like a question for Knowsalot.
Old Jul 2, 2002 | 10:12 PM
gaff's Avatar
call mega cam, this is what your looking for, get the springs and keepers from them.
If it's the rev you want go get the rev limiter first, this will be the best way.
Cams don't alter the jetting or power you have. What they do is take the power you have now and move it to some where else, so jetting won't change.
Enless your racing, get the rev limiter first and then look at what you want.
Old Jul 3, 2002 | 11:07 AM
MOJAVE02's Avatar
ok thanks
Old Jul 3, 2002 | 08:08 PM
mojavekid13's Avatar
I just wanted to know!!! where i could get my rev limter re-maoved???? I live in cananda so ,......any ideas???
Old Jul 4, 2002 | 12:26 AM
KawasakiMan's Avatar
i think you buy a xlr200 box or something
Old Jul 4, 2002 | 01:04 AM
mojaveman1's Avatar
you can either send it to fst and they will remove it or you can buy the klr box
