Oil coming out of engine head!!!!!?
Old Jul 2, 2002 | 12:51 PM
TRX350dude's Avatar
i have oil on the top of my rancher engine on the sparkplug side. where could it be comeing from? i cant find a leak anywhere. ive checked the oil level and its correct.at one time it was high but i lowered it, cleaned the oil off but it still does it. does anyone else have this problem? i run my rancher like a banshee, could this be the problem?
thanks in advance,
Tommy
Old Jul 2, 2002 | 05:19 PM
350rcherdude's Avatar
it could be just top end gaskets but it is new so i dont see why they wold leak. how about valve covers.coompresson release ?? i dont rember it has one.
Old Jul 2, 2002 | 06:47 PM
TRX350dude's Avatar
i have about 4300 miles on it if that helps
Old Jul 2, 2002 | 07:42 PM
2fat4moto's Avatar
I have a Prairie 650 & the differential vents are under the handlebars to stay away from moisture. I have had mine spew out oil all over my engine. Freaked me out until I figured it out. Hope this might help.
Old Jul 3, 2002 | 06:13 PM
that is alot of miles. but my 350x is still on stock gaskets from 86 and that has ungodly amount of miles. it could be a breather vent. have you ever flipped it over??
Old Jul 4, 2002 | 07:05 PM
Elrancho's Avatar
The valve cover on the rancher is O ring sealed, if there is any damage to the oring or debris at all they won't seal. Another words barring a cracked/warped head or cover, take the cover off and get a new Oring for it. If the dealer adjusted the valves get him in the pants till he pays for the oring too. If it's a cracked or warped problem you have other trouble coming up.
Old Jul 5, 2002 | 07:36 PM
prang11's Avatar
Did you over fill it last time you changed the oil? To much oil will raise oil pressure and blow seals. How long did you run it twith high oil? Try draining all the oil then refilling with new oil. If it still leaks then take the head off and put a new gasket in it.
SOLOLUCKY
Oct 4, 2024 09:09 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
wbfjim
Jun 8, 2015 06:20 PM
