More 400ex Power??
Old Jul 3, 2002 | 12:01 AM
camegam's Avatar
I have a 01 400ex with about every bolt on there is. I just recently put on Elka shocks which are amazing. However I do need more power. Some of these races with long straights,,the dales are eating me alive. Tight courses I can hold my own. My motor has never been touched(bore,cam,piston) are stock. Anyone have a set up???
I would prefer to stay(more or less) with the stock bore,,just hone it and go with a high compression piston to retain the reliability.
What about cams,or carbs????
Any ideas????
Thanks
Old Jul 3, 2002 | 05:20 PM
Honda55's Avatar
If your talking mx, I'd say put a Crf450 motor in it. That'll give the C-dales something to think about. If not, give Tc racing a call, I'm sure they could hook you up in some way. Bottom line is your going to have to get a bigger displacement to hang in there on the straightaways.
Old Jul 3, 2002 | 05:35 PM
timewass's Avatar
You could bore just slightly larger to get a 416cc or just go all out with a 440 kit.
Old Jul 3, 2002 | 05:47 PM
camegam's Avatar
How reliable do you think the 416 or the 440 would be??
I run hare scrambles from 1-2 hours hard on the throttle.
Thanks for your help!!
Old Jul 3, 2002 | 07:27 PM
Mr350X's Avatar
If you do the 440 kit, make sure you change out that rod.
Under those circumstances, it wont last long being pounded by a 440 high compression piston.
It will be reliable if done right.
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
