compression ratio?
Old Jul 3, 2002 | 01:30 AM
badR's Avatar
How do you get the compression ratio of a motor? Is there some kind of formula?
Old Jul 3, 2002 | 05:55 PM
AlkyBurninX's Avatar
2-stroke are harder to figure compression on since they have the ports in the cylinder and the intake charge is somewhat pressurized.
4-strokes aren't that hard. You must know the cylinder displacement, the size of the piston dome, the thickness and diameter of the torqued head gasket, and the size of the combustion chamber. Take the combustion chamber size in cc and add the volume of the head gasket. Subtract the dome size in cc from this number. Divide the cylinder volume by the new number. This is an estimated compression ratio. To be exact you must calculate ring height, valve pocket size, and many other factors.
It took me an hour to write this due to interuptions, so if someone has posted before I finished, I appologize.
Old Jul 3, 2002 | 08:13 PM
badR's Avatar
Thanks for the info. Seems like alot of trouble.
Old Jul 19, 2002 | 04:29 PM
MX265X's Avatar
why not use a compression gauge and thread it into your spark plug hole and kick the motor over until the little needle no longer moves and that till tell uyou your compression in pounds per square inch that sounds a little easier huh?
~Eric
Old Jul 28, 2002 | 02:29 PM
DaKster's Avatar
buy doing this it will give you a psi number which you can divide by 14.7 to give an estimated CR. the problem is that if your rings or seals are not good it will read a low psi and then give you a false CR. this is a mickey mouse way of doing it. If you are doing this because you are building you engine and want to see if you will need high octane fuel than the results will lead to failure. try finding out as much info as you can then go here.http://www.csgnetwork.com/compcalc.html
Old Jul 28, 2002 | 02:40 PM
THEMOOSE's Avatar
When checking the compression with a guage like MX265X said, you must open the throttle completely while kicking it over or you'll get a false reading!
Old Jul 29, 2002 | 01:38 AM
badR's Avatar
My compression is 220, I have a compression checker. I was wondering how to get your compression ratio.
Scooter's Shop
Oct 9, 2015 02:09 PM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Steeldon
Sep 9, 2015 09:38 AM
