Greasing the Raptor?
Old Jul 3, 2002 | 01:42 PM
Area51's Avatar
Well, I have had the Raptor out for some serious play time, and I love this machine [img]i/expressions/face-icon-small-happy.gif[/img] But after bringing it home washing it, cleaning the chain and re-oiling it, I thought I better check with you guy's about how often I should hit all the grease zerks? I was surprised to see so many of them, after owning a Prairie 650 with all sealed bushings. Anyway, how often should I grease it, and is it the normal procedure of greasing it until you see grease come out of the bushing/bearing? I ride in dry desert conditions, no water here, just loose powdery dirt, gravel and sand. Thanks for the info guy's.
Old Jul 3, 2002 | 04:30 PM
THEMOOSE's Avatar
I do a full service (adjust valves, Change oil, clean oil filter, clean air filter, Change spark plug, Lube & generally check things over) every 20 hours.
But I'm a bit picky about my quad!
I add grease till I just start seeing grease come out the seals.
I then clean the excess grease off & I put vacume caps on all the zerks for protection.
Old Jul 3, 2002 | 04:46 PM
velocityraptor's Avatar
<< I do a full service (adjust valves, Change oil, clean oil filter, clean air filter, Change spark plug, Lube &amp; generally check things over) every 20 hours.
I then clean the excess grease off &amp; I put vacume caps on all the zerks for protection.
This is good advice to follow. (about every 20hrs)
Old Jul 3, 2002 | 06:08 PM
klj's Avatar
klj
Moose,
What are vacuum caps? Are they caps that push onto the zerk? Sounds like a good idea, where can I get some?
Old Jul 3, 2002 | 06:34 PM
RaptorRy's Avatar
What type of grease do you suggest? and how long does it take to adjust your valves?
Old Jul 3, 2002 | 06:38 PM
klj's Avatar
klj
RaptorRy,
I use synthetic grease on mine. Works great.
Old Jul 3, 2002 | 07:42 PM
Ward660R's Avatar
Does anyone else find it hard to get to the upper a-arm zerks? When I first got mine they didn't even have grease in them.
Old Jul 3, 2002 | 07:54 PM
Area51's Avatar
Thanks for the info guy's. Sounds like a good schedule to me. I ride on average about 3.5 hours at a time, once a week. So I will need to service it at least every 6 weeks, which would work out to be about 21 hours, with air filter cleaning a little more often. Thanks again.
Old Jul 3, 2002 | 09:49 PM
THEMOOSE's Avatar
You can get vacume caps at any auto parts store. They are just a rubber cap that keeps crud off the zerks.
I use a Mobilith AW-2 industrial grease.
It usually takes about an hour just for the valves but I've never rushed through it &amp; I take time to check all the fasteners &amp; clean the areas that are inaccessable when the tank &amp; plastic are on.
I'm going to replace all the tough zreks with angled head zerks so they'll be easy to get to.
Any one know if metric pipe threads are the same as SAE pipe threads?
Old Jul 4, 2002 | 02:49 PM
2fiftyX's Avatar
You should stop greasing immediatly when grease is coming thru the seal because the grease will blow the seal. It would be best to stop before the grease comes thru but it's hard to tell when.
Lithium grease is what is called for in the manual and that's what I use.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
bigred20653
Sep 19, 2015 02:11 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
