Warrior problem - not starting
Old Jul 4, 2002 | 10:54 AM
SheesTheOne's Avatar
HI Guys
A friend has a 2000 warrior that has been giving a lot of trouble. It first started with the bike battling to start, and now just doesn't. After checking fuel lines,carbs etc, we noticed the spark is very faint. We replaced the plug And it seems fine for a while, now even with new plugs, NO GO . Any Ideas, coils,electrical wires etc . The stator "looks" fine.
Thanks in advance
Old Jul 4, 2002 | 12:39 PM
95wolv's Avatar
If the spark is weak, a coil may help,see if you can find a buddy with a Warrior to swap off of,just takes a few minutes to hook it up,saves buying all those expensive parts,keep swapping until something makes a difference. You said the stator "looks" fine, a visual check will not show an open wire,also,the gap to the firing coil needs to be pretty exact,I had a bad miss in my Wolverine (same engine),it turned out to be the stator gap to the firing coil was too wide,if yours is off more,or somegthing moved,your spark would be very weak.
Old Jul 8, 2002 | 11:46 AM
Thanks 95wolv
Looks like he's taken it in to get fixed. I'll post a fix as soon I I know the answer ...
Old Jul 16, 2002 | 08:02 AM
Looks like it was the pickup coil, had it rewired ...
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
