Piston removal questions......
Old Jul 9, 2002 | 01:42 AM
02BAJA's Avatar
I am rebuilding my first atv. You will never learn until you try right? Well, I just want to make sure of something before I take it apart. I have the head and all that off. The only thing left is the cylinder and the piston. Do I just unbolt the cylinder from the base and pull it off the piston, or is there a better way? Also is ther anything to do or look for when outting the new piston in? Also where are the timimg marks on the cam and crank gears? I looked but couldnt see any.Thanks.
Old Jul 16, 2002 | 04:37 PM
timewass's Avatar
I'm not dissing you or anything, but an ATV is a pretty tight tollerance engine. I think your next step should be going to your local dealer and getting a shop maunal or visit Clymer.com
Old Jul 16, 2002 | 11:48 PM
Varmit's Avatar
Timewass is right the best investment you can make is a Shop Manual for your Quad. It will answer a lot of questions and save a lot of time...
And yes you pull the cylinder off the piston. Be carfull to hold the rod as it comes off so you don't damage it.
Old Jul 16, 2002 | 11:59 PM
Sandgod's Avatar
Always put a rag around the rod in case you drop a circlip or something else. Won't go down to never never land....
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
atvcollector
Sep 8, 2015 05:11 PM
Jason Richards
Sep 4, 2015 06:17 PM
