compression reading
Old Mar 14, 2000 | 03:45 PM
Ron70's Avatar
Can anyone tell me what kind of compression a 300 polaris should run? According to the twp different dealers Ive talked too, one says 100 , Anything less is no good, another said as long as its at least 50.. Any answers?
Thank you!
Old Mar 15, 2000 | 03:53 PM
truck's Avatar
POLARIS factory manual says 100psi min.
GOOD LUCK
TRUCK
Old Mar 16, 2000 | 08:05 AM
Ron70's Avatar
Thank You! Is that hot engine or cold? I know the readings will be different between hot and cold!
Thanks again!
Old Mar 16, 2000 | 08:56 AM
truck's Avatar
The correct way is warm engine,air filter removed,while holding the throttle wide open.
Crank 4 to 5 seconds.
GOOD LUCK
TRUCK
fordfaithful21
Dec 7, 2015 05:52 PM
atvcollector
Sep 8, 2015 05:11 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
Mphillips
Jul 2, 2015 07:20 PM
