carbs
Old Jul 17, 2002 | 11:23 PM
yammy660r's Avatar
why does the raptor have two carbs instead of one larger carb?
Old Jul 18, 2002 | 02:07 AM
THEMOOSE's Avatar
I think 2 small carbs have more velocity than 1 large carb, that means more low end & more precise fuel metering.
Old Jul 18, 2002 | 12:50 PM
AlkyBurninX's Avatar
Moose is right. Small carbs keep a higher velocity because they keep more vacuum. At WOT the two carbs flow as much as a very large one. Best of both worlds.
My question: A 2 carb setup is supposed to help low end and topend. Now look at a ad for a single carb setup for a banshee. They claim that it adds lowend and topend (has nothing to do with 2/4 stroke). Funny huh?
Old Jul 18, 2002 | 02:11 PM
Elrancho's Avatar
Um...air flow is air flow, twin carbs are fine on the banshee and raptor, the raptor may breath slightly different from one intake valve to the other, so the extra carb may not be a waste, it's just a bit more tunable than a single. The banshee's twin carb is much more important, an entire cylinder may not be quite the same as the other( this is more pesky on two strokes too. ) Polaris's single carb twin (sp700)is kind of half arsed, the only good thing about it is, constant high air flow through the single carb, but if one cylynder is off a bit it's not going to be helped untill a rebuild.
edit added: The grizz's single phat carb seems to do pretty good too, If I'm not mistaken it has a different cam and still produces near raptor HP out of the single carb, (with the same cam they'd probably be spot on HP, but the raptor would still rev faster do to lighter tranny components, and twin carbs getting to work faster.)
Old Jul 18, 2002 | 10:05 PM
Ward660R's Avatar
Not to disagree with everyone but I inquired about the Edelbrock set-up a few months back and was told just the oppisite. I can't remember who it came from but I think it was a good source. This is the reason I ruled them out for me, I wanted the gain in the top not the bottom.
Old Jul 18, 2002 | 10:23 PM
spacollie's Avatar
I think also you will atomize the fuel better with 2 smaller carbs as apposed to 1 big one.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
