250r thumb throttle way stiff! Please help
Old Jul 21, 2002 | 01:06 AM
mxer's Avatar
I finally got to hook my throttle cable up to my new 38pwk
carb. The throttle is reallllly stiff now.
I heard many roomers on what to do to make the throttle
easier. Cut the spring, file the spring, play with the spring, or use the stock carb spring?
What should i do. The throttle is alot stiffer than any other R i have rode.
matt
Old Jul 21, 2002 | 12:28 PM
trapperb1's Avatar
First, remove the little spring inside the throttle housing and lose it.
Next, don't cut the spring length, not good. You can take it out, put something inside it to help hold it and then "file" it down using some sandpaper.
Make sure the cable has no kinks or hard turns in it. If the cable is not new, lube it good and make sure there aren't any frayed ends, etc.
Alex Rodak
Sep 13, 2015 12:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
