Water Temp. Gauge?
Old Jul 27, 2002 | 03:04 AM
lilnotts's Avatar
Does anybody have one that is on the dash? the esr gauge is nice but i don't wanna look down while i'm ridin to see the temp, has any got any idea? i'm on a tight budget to so somethin cheap would be nice
Old Jul 27, 2002 | 03:18 AM
Hightower's Avatar
I just let my red warning light notify me of a problem. If it comes on then I would stop like I should and shut the motor off. Then I can look down at my ESR gauge to see if it actually is overheated. If the gauge reads the correct operating temp then I can assume it is lack of oil pressure.
Good luck, hope you find what you're looking for.
For your future info: Thermostat opens at 185, fan comes on at 203, red warning light shines at 239 degrees. On a real hot and nasty day, operating temps at slow speeds through tight trails can get up to 220 until you hit a straightaway and flow some air over her, so whatever you get needs a range of 0-250 degrees to really be of use. A lot of them only go to 220, which doesn't do a lot for you.
Old Jul 27, 2002 | 10:30 AM
smitty911's Avatar
Trinity has a digital water temp for 69 bucks. It's about 3 inches by two and comes with the termocoupler.
Smitty
Old Jul 27, 2002 | 10:36 AM
DSjockey's Avatar
Here's some choices Guages the digitals are compact and might fit on the dash by the key leaving the tach space open for a tach, there's also the analog at the bottom of this page that splices into the upper radiator hose
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Logan Collins
Sep 5, 2015 08:03 PM
