Airbox lid, on or off?
Old Jul 31, 2002 | 10:23 PM
JMAC650's Avatar
I see alot of people take off their airbox lid. The question I have is how much power do you gain from this and what kind of jetting do you need for sea level with a K&N and a aftermarket slip-on exhaust. Do you lose any reliability?
Old Aug 1, 2002 | 12:11 AM
spacollie's Avatar
Reliability you will not loose unless you suck water in your engine. You will loose some bottom but you will gain on the top if done correctly.
2001 raptor, ct pipe, pro-flow foam, air box mods,
tag x-5, razrs, 12 tooth front
spacollie's Avatar
Old Aug 1, 2002 | 01:38 PM
918sTaxi's Avatar
You lose power on the bottom end from taking the lid off? Are you sure? If that's the case then I'm putting mine back on, that would negate what the slip-on is doing for me.
Let's hear some other opinions
Old Aug 1, 2002 | 01:43 PM
DSWOLF's Avatar
I have the alba pipe kit,k&n straight on the carb 190 dynojet and i ride at 500ft trust the bottom end is much more powerfull.
DSWOLF.
Old Aug 1, 2002 | 02:23 PM
JMAC650's Avatar
The reason i'm asking is I went to pismo and noticed it was kind of sluggish so I pulled the airbox lid off and it was alot more powerful, but the problem was it was backfirering alot so I put it right back on. I just want to know if it is worth the power to take it off?
Old Aug 1, 2002 | 02:36 PM
biggerisbetter's Avatar
It was back-fireing because it was to LEAN, take the lid off and rejet your carb to a 185 mukuni or a 195 dynojet(main jets). Then turn your Idle/mixture screw in all the way,then out 3 turns.
Biggerisbetter.
Old Aug 1, 2002 | 02:51 PM
JMAC650's Avatar
Biggerisbetter;
What clip is your needle on? Is it stock or dynojet?
1986Vmax540
Jul 9, 2021 09:53 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Dammar
Aug 26, 2015 07:12 PM
ghost civic
Jul 20, 2015 12:36 PM
