Can't decide-Boyesen Rad Valve or Delta V-Force
Old Aug 1, 2002 | 06:20 PM
adamnieman's Avatar
I am working my way on up to HPD's Trail Mod kit. All I need now is porting, bigger carb, and some better reeds.
Problem is I don't know who to go with. I have heard good and bad about both, and then theres the reed spacer issue. I have done some research on both....
1. HPD only sells Delta V-Force.
2. Reeds spacers claim to add power and help reeds last longer.
3. Dyno tests prove that the Delta's produce slightly more power then the Boyesen Rad Valve.
4. Heard from a few that if you don't run a reed spacer on the Delta's that they will not last that long.
5. Boyesen claims more top-end power while Delta's claim more low to mid gain.
6. Both are in the some price range $130-160 depending on who you are dealing with.
So, who's it going to be? Whoever I go with should I get a reed spacer? Do I need one with the Boyesen Rad Valve? Which one lasts longer and have any of you had any problems with either? Thanks.
'96 Scrambler with HPD mods.
Old Aug 1, 2002 | 06:38 PM
scramblered's Avatar
well man i tried them both,last year was running RAD valve,i now this year i run v-force 2,what i noticed the boyesen "snap" harder at top end and seem to get better powerband,but the v-force are the best about throttle response,they are crisper and quicker,i think both reed system worth the money...
i was always running the reed spacer with both reed cage.
Old Aug 1, 2002 | 06:44 PM
and if you mind about wich one last longer,ALL aftermarket reeds,NEED petals replacement EVERY year to get max performances,so...
Old Aug 1, 2002 | 08:02 PM
modquad's Avatar
There's a reason Darrell (HPD) only sells v-Force II's. The dyno proves it, run the spacer.
Ken
Old Aug 1, 2002 | 09:27 PM
Snoopy61's Avatar
Ken,
Does he really need the spacer?I thought that the spacer was for Big Bores? I have the trail kit without the spacer. Would itbenefit me to get a spacer?Sooooo many questions. HPD or RCR did not say I needed a spacer.
Ronnie
Old Aug 1, 2002 | 10:14 PM
modquad's Avatar
I would say run the spacer. It's only questionable with the big bore kit. Heat and vibration are enemies of composite materials. The farther away from the heat of the combustion process can't hurt.
Ken
Old Aug 2, 2002 | 01:42 PM
adamnieman's Avatar
I have heard that it is suggested to replace reeds yearly. Kinda like dirt bikers re-ringing their pistons every couple races.
Might just save the $30 for the spacer and put it towards new reeds when needed....or maybe porting! smile.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
