Tourqe Specs
Old Aug 2, 2002 | 07:03 PM
BigBlack's Avatar
Hate to ask but need a favor from those who have a service manual, mine is on order but I will not have it in time for the re-assembly.
I am installing the trail tech and would like to know the tourqe specs on the following nuts and botls
Front Spindle Nut
Brake Caliper Bolts
Rock Shield Bolts
HandleBar Clamp Bolts
Rotor to Hub Bolts
Old Aug 2, 2002 | 07:46 PM
THEMOOSE's Avatar
Here ya go,
Front spindle nut, (Axle nut) 70 NM(7.0m~kg 50 ft lbs)
brake caliper bolts, 28 NM (2.8m~kg 20 ft lbs)
Rock shield bolts, Sorry I didn't see one listed, I just got them snug & used blue loctite.
rotor to hub bolts, 28 NM (2.8 m~kg 20 ftlbs)use blue loctite
Handle bar bolts, 23 NM (2.3 m~kg 17 ft lbs)
Old Aug 2, 2002 | 07:48 PM
spacollie's Avatar
Front spindal-50ftlbs[hub]
Brake caliper-20ftlbs
Rock shield-N/A[probably in the area of 17ftlbs]
Handle bars-17ftlbs.
Rotor to hub-20ftlbs.
The rotor to hub should torque properly as not to warp the rotor but the others I wouldn,t be so worried about. Torque till you feel comfortable.
Old Aug 2, 2002 | 08:00 PM
BigBlack's Avatar
Thank You
Lots of experience here
Maybe one day I can return the favor!
raman8tor
Sep 20, 2015 07:35 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
toonces
Aug 21, 2015 01:19 PM
