500 automatic windes out help!!
Old Aug 5, 2002 | 05:10 PM
profish00's Avatar
Ok here is the deal the bike runs fine but it windes out at high speed it acts like the clutch is going out anyone have a fix for this???
Old Aug 5, 2002 | 07:55 PM
bigjohn513's Avatar
i got an idea for ya...take it out of low...
Old Aug 5, 2002 | 08:59 PM
mudcat47537's Avatar
How about a little more detailed information.
Old Aug 7, 2002 | 08:08 AM
CrazyCat's Avatar
If you have the throttle pegged, it could be the rev limiter.
Old Aug 8, 2002 | 01:41 PM
MegaCrash's Avatar
If its a new problem and used to run a lot faster, its possible that there is a problem with either the primary or secondary clutch. You could take off the cover and make sure both clutches open and close properly, and that no foreign object are in there.
Old Aug 8, 2002 | 02:20 PM
profish00's Avatar
Thanks,I will check all those options and (bigjohn smoke another)I think of you every time I "P"
Old Aug 8, 2002 | 03:03 PM
SurferSam's Avatar
It sounds like too many others have been riding and doggin' Oloneeye's quad. If I were him, I would keep Jason off the bike.
Old Aug 9, 2002 | 12:00 AM
bigjohn513's Avatar
damn didnt know you couldn't take a joke
Old Aug 13, 2002 | 03:04 PM
powercat's Avatar
I think a joke is the last thing someone wants to hear when they have problem with something.
Old Aug 13, 2002 | 03:14 PM
SurferSam's Avatar
I was with the guy on one occasion when his bike would not move. Ol'oneeye had been stuck in a deep mudhole and had to be pulled out. Immediately afterwards, the bike wouldn't move. My first thought is a wet belt from a leaking clutch cover. His bike was repaired last year because a bearing on the transmission by the driven clutch was squealing. A $400.00 repair later, he says the noise is coming back. Is his cover leaking water and in turn causing the belt to slip as well as scorch the bearing on the transmission again? Any help is appreciated.
SurferSam
vandammages@gmail.com
Aug 20, 2020 11:50 AM
akguy31
Aug 31, 2019 04:34 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Elkaholic
Sep 6, 2015 02:44 PM
