1988 Moto 4, need a little help
Old Aug 10, 2002 | 11:31 AM
nigman's Avatar
I have a 88 Moto 4 that won't run. It has spark and it turns over but for some reason it just won't run. I could be something simple but I'm not sure. Any suggestions would be great. Thanks
Old Aug 10, 2002 | 06:46 PM
disturbed660's Avatar
hey i used to ride those years back...
u may try some new gas, clean the filter, do a compression test, play w/ the carbs make sure nothing is stuck or pluged, or just take it to ur local yamaha shop
good luck man
Joel
Old Aug 10, 2002 | 09:55 PM
warrior007's Avatar
Get to the basics, you need 3 things for an engine to run:
        Verify that your getting fuel by trying starting fluid directly into the carb while trying to start it. if it starts or fires you know its a fuel problem.
        Verify that you are getting spark, take the plug out and inspect it, the let it lay and ground itself on the motor, turn it over and you should see spark (better when its dark)
        If you have both of the above and they are good, go for a compression check, either go to pepboys and get your own guage or have the dealer do it.. threads right in where the sparkplug goes
        Old Aug 11, 2002 | 07:12 PM
        nigman's Avatar
        Thanks for the help guys! I cleaned the carb and check for spark, there is spark and it is getting fuel. I'll try the compression test next weekend.
        Old Aug 12, 2002 | 01:09 AM
        warrior007's Avatar
        If your compression is up to snuff then you will need to check out your timing. If you have all 3 of the above and the timing is right it has got to run
        wendal
        Aug 3, 2024 10:03 PM
        Valder
        Nov 28, 2020 07:38 AM
        fredrikrosen
        Oct 29, 2016 07:56 PM
        zPuls3
        1) Engine problems..
        Sep 12, 2015 08:54 AM
        mrmickman123
        Technical and How-To Articles
        Aug 30, 2015 10:37 PM
