1988 Moto 4, need a little help
Get to the basics, you need 3 things for an engine to run:
Verify that your getting fuel by trying starting fluid directly into the carb while trying to start it. if it starts or fires you know its a fuel problem.
Verify that you are getting spark, take the plug out and inspect it, the let it lay and ground itself on the motor, turn it over and you should see spark (better when its dark)
If you have both of the above and they are good, go for a compression check, either go to pepboys and get your own guage or have the dealer do it.. threads right in where the sparkplug goes
