Rear Brake Help needed here.
Old Aug 14, 2002 | 01:07 AM
bigwave's Avatar
From: South Central Illinois, NO where near Chicago, that's not my Illinois
I have a 90cc kid quad ( an IPC Pitviper 90 ), that I decided to put some better brakes on the rear. Here is what I did: It now has a Polaris break lever/Caliper mounted on the Left side handlebar, it also has a Front brake master cylender from a Polaris utility quad now on the rear disc. I made a 1/4" inside diamiter hydrolic hose for the brake line.
Here is my issue, I figured if this front brake caliper will help stop a 700lb Polaris utility quad it will easily lock up the rear end of this little 190lb atv. Well, guess what? It don't, I have bled it, and it's tight as a drum at the lever but it just doesn't grab like I thought it would. Now the caliper and brake pads are brand new so, could that be the problem? Do they have to wear some before they grab well? For ATV pads these pads are very large and touch allot of surface area of the disk. Are the OEM Polaris pads not very good? Are there after market pads that will grab better? Is my hose inside diameter to large or to small? I mean the brakes work exactly as they should, they just don't have the stopping power I thought they would.
Any ideas?
What do you all think?
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
AK47KID
Jul 23, 2015 09:21 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
CountryMiles
Oct 25, 2000 01:03 AM
