cr250 cylinder on a trx250.
Old Aug 14, 2002 | 02:25 PM
FTM's Avatar
FTM
Does anyone know if a cr250 cylinder will fit on a trx 250r?
Old Aug 14, 2002 | 04:38 PM
CBUS660R's Avatar
On newer CR cylinders, no. They are case reed inducted so you would have no intake on the cylinder to mount the reed cage like a TRX cylinder. Older CR cylinders may work, but would probably require some machine work either on the cylinder, the cases, or both. I know there are companies building motors with CR500 and Polaris 400 cylinders so it has to be possible and there probably is someone doing it, I just haven't seen it.
Old Aug 14, 2002 | 07:39 PM
Sandgod's Avatar
Dennis Packard of Packard Enterprises would know. He is the Honda guru. He's in Farmington, Utah. I don't know the number. This guy has tried everything to Honda's and he will be able to tell you anything and everything on them.....
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
