Foreman electric fan
Old Aug 15, 2002 | 04:38 PM
signguy's Avatar
Hey everybody, I have a 2002 Foreman 450 S, and have noticed that my electric fan has not kicked on once. Now my temp light has not come on, and it really didnt worry me until the other day I rode with someone with the same quad and his kicked on quite often. I called the dealer and asked and they told me to just check the fuse which I did and it was fine. Maybe I'm being paranoid but its only a month old and I really dont want to mess it up. Anyone else ran into this prob...or have any suggestions. Thanks in advance
Old Aug 15, 2002 | 05:46 PM
MSRoadkill's Avatar
signguy....i have a 2000 foreman 450s and so does one of my buddies...... we usually ride together and his kicks on way before mine most of the time....his is a 2002 model....guess it just depends on the bike......my 2 cents....
Old Aug 15, 2002 | 06:00 PM
450HondaForemanS's Avatar
I have a 2002 450S. The fan doesn't kick in unless you are moving really slow for a while which causes the engine to build up heat. In the right conditions I can ride for hours and it never kicks in. My friends sp700 overheats before my fan kicks in(honestly). If it is hot and I am crawling through the woods it takes at least 30 min before it gets hot enough for the fan to kick in. By the way the pre 2002 are full time 4wd so they should heat up just a little faster due to the higher constant load on the engine.
Old Aug 15, 2002 | 06:01 PM
Does anyone notice a clicking or ratcheting sound if they brake or downshift coming down a hill on the 450?
Old Aug 17, 2002 | 09:55 AM
foremannn's Avatar
I have the same quad and i noticed that after about an hour of hard trail riding the fan seems to kick in and out pretty consistenly. I asked around and was told that how you ride the quad has some to do with how much heat builds up in the motor/gearbox. Meaning how often you shift, hills, ect. If you look at your quad by the shift lever (or where it would be if it is es) thats where the heat sensor is for your fan so if you tranny is hot from hard shifting or bogging your motor it will cause the fan to run more. Hope i helped a little.
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
