Best thing to buy with $300
Well flipping the front rims around helps the handling alot. Although you have to relocate the valve stems on the other side of the rims while turning the original valve stems around so they are in backwards.
The tires make a huge difference, so doesn't the exhaust.
Go to rockymountainatv.com and see what tires and exhaust will run you.
I want an exhaust that will give me power, and mostly sound. The pipe I have on my EX sounds sweet, it makes that GREAT low tone grunt when you hit it. It now has a Cobra (Yeah I know), the guy brfore me instaled that. What makes that sweet sound I'm talking about.
I think the pipe will give it a graet deal of snap, just I kicked myself for not getting tires and shocks sooner. When I got all the HP it was nothing untill I could get the chassis and tires on, then it was awsome.
$300? Hmmmm..... well I would say a 13 tooth front sprocket($15) a 41 tooth rear sprocket($40) a k&n power kit ($100) and 2 Shredder,razor or holeshot rear tires($140)(assuming yours are bad). And $5 worth of gas to test it out! Now if your tires are in decent shape, this would change everything. If your tires are good I would scrap the rear sprocket suggestion along with the tires and take the $180 and maybe get the FMF mega max II. If you still can't decide you could always send a check made payable to "2000 Mojave" to my house and I will spend it wisely for you![img]i/expressions/face-icon-small-wink.gif[/img]
