Rear brake light stays on.
Old Aug 19, 2002 | 04:50 PM
65fl's Avatar
The lever appears to be loose, I haven't really looked at it to see if it needs adjustment or if I lost a spring or something. Any ideas?
Thanks
65FL
Old Aug 20, 2002 | 10:56 AM
bbertram's Avatar
Crappy electrical, my rear tail light doesn't light up when I press the brake, only when I press the foot brake. I would blame electrical.
Old Aug 20, 2002 | 12:18 PM
powercat's Avatar
65fl, I have had a similar problem on my 01. I assume you are talking about the left disc hand-brake. My lever is always loose, I assume this is by design. When I spray my quad down after riding, the grease that is on that small cylinder that pushes in when you brake gets washed away. I use some 10w-40 or Tri-Flow to get the thing moving freely again. Without it, my brake light stays on too..
Hope this helps
Old Aug 21, 2002 | 11:23 PM
k20arctic911's Avatar
No it doesn't it need adjustment and you didn't lose a spring.
It is the junky master cylinders that AC puts on them. I had mine replaced. Works fine now.
Old Aug 22, 2002 | 09:15 PM
redneck76's Avatar
Brent
I had the same problem and thought crappy electrical also. Didnt check it for the longest time.Finally did yesterday. The small cylinder that pushes in has a plug on it about 1 1/2 feet down the cord. Mine was unpluged. Check yours out.Maybe thats all it is.
Old Aug 23, 2002 | 10:27 AM
65fl's Avatar
I got the chance to take a look at it last night, powercat and k20 hit the nail on the head. Basically it is the master cylinder plunger that is sticking causing the lever to be loose, thus not making contact with the switch. I soaked it with some wd-40, didn't seem to help. Has anyone ever bothered to tear it apart and see if this is caused by corrosion and if it can be rebuilt? Does anyone sell a rebuild kit, if not how much is a new one?
Thanks again for the help,
65fl
Old Aug 24, 2002 | 12:30 AM
redneck76's Avatar
i
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
rcappie4
Jul 10, 2015 04:54 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
