Warrior neutral light won't work
Old Aug 19, 2002 | 09:53 PM
warrior350megamax's Avatar
sup guys,
well I've had this problem for a while and I still can't figure out what is wrong. I have figured out that it is not the bulb and that it is getting power. Is there a gound wire or a wire from the trans that could be missing? have any ideas where they are on the Warrior? thanks in advance for the help, any info appreciated,
Patrick
Old Aug 19, 2002 | 10:56 PM
anyone?
Old Aug 19, 2002 | 11:01 PM
paintblaster41's Avatar
there is a connection around the gear shifter mine falls off everynow and then the light just stops working my wire is green and it is thin
Old Aug 22, 2002 | 11:10 PM
turbomitch's Avatar
Some things you may wish to check. The Warrior uses a common brown wire for many of the circuts, this includes your neautral light. You may check your continuity on that wire. The other thing is the neutral safety switch that is located below and forward of your shifter on the case. You should disconnect your wire from it and perform a ohm check on it as well. The neutral safety switch is spring loaded and when you shift out of neutral the gear inside the case moves and allows the spring to move forward on the safety switch putting the circuit to an open position. When it is in neutral the spring inside the switch is compressed putting the circuit in a closed state, thus lighting your light. Usually if this switch is bad you will not be able to start the Warrior w/o pulling the clutch in. If you pull the switch out be carefull because oil from the case will leak out. I suggest either draining it down some or tilting the bike on it's side for a short period. The new switch is about $23.00 from the Yamaha shop.
Good Luck.
Old Mar 18, 2015 | 08:58 AM
Quadbc's Avatar
Good Luck.
Turbomitch, what should the ohms be when checking these. Just to verify continuity or is there a number I should see?
I have done it and get a reading of around 204...
Old Mar 18, 2015 | 08:59 AM
Quadbc's Avatar
Default 2001 Warrior Neutral Light
ripperray
Oct 10, 2023 02:42 AM
Mkp
Mar 28, 2020 03:50 AM
jonathongolden250
Jun 23, 2015 04:36 PM
Nelson
Jun 20, 2015 01:59 PM
jayking232003
Jun 9, 2015 02:54 PM
