Timing question on a WARRIOR
Old Aug 20, 2002 | 02:19 PM
Spaceout02's Avatar
I have a 92 warrior and what do i need to line up on the gears when i put the timing chain back on. do i have to take the side over off and use the 2 marks that have a T and F by them or ??? Please help
Old Aug 20, 2002 | 04:16 PM
WarriorManiac's Avatar
Remove the black sight screw on top of crank area, gearshift side. Align "T" timing mark with notch in window. Align camshaft gear mark with mark on head. Your in time.
Old Aug 20, 2002 | 04:21 PM
Spaceout02's Avatar
Thank you much, That helps a lot. Thanks
Old Aug 20, 2002 | 05:11 PM
Spaceout02's Avatar
WHat line on the head does the gear need to be lined up with. Thanks
Old Aug 20, 2002 | 06:05 PM
Best I remember the timing mark on head is at about 11 o'clock. A dot or a triangle?. Also remember the manual saying (don't have manual anymore) the dow pin on the camshaft will be about 12 o'clock.
Hope this helps.
Old Aug 20, 2002 | 11:10 PM
RaceWarrior350's Avatar
be careful dont make it a tooth or 2 advanced it can cause it to bend the valves. just sayin, i just rebuilt mine i got it perfect on the first try, and get a service manual it helps =)
SOLOLUCKY
Oct 4, 2024 09:09 PM
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
ZJnut
Dec 30, 1999 08:33 PM
