02 and newer Raptor reverse rev limiter
Old Aug 20, 2002 | 11:22 PM
did's Avatar
did
If you need more power backing up all you need to do is remove the wire for the reverse light just below the counter shaft sprocket and ground it. You will lose the reverse light but will have full power backing up.
Old Aug 20, 2002 | 11:50 PM
RaptorOwner's Avatar
Is there any way you can just ground the reverse wire at the light? Just so I dont have to cut any wires.
Old Aug 21, 2002 | 10:02 PM
did's Avatar
did
you have to ground it at the switch and not the light. This fools it into thinking you are not in reverse and cuts out the limiter
cornermike
Sep 10, 2015 08:30 AM
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
