clutch adjustment for 86 200SX.
Old Dec 11, 1999 | 01:02 PM
RangerSX's Avatar
Well i need some help boys..... My 86 200SX is quite old and has been maintained fairly well. The problem is when in 4th or 5th gear and i have it pinned to the bars. I can feel the clutch slipping underneath me. this especially happens when in 5th and cruising at about 50mph. i know the right side of the machine has the clutch adjustment screw. but i did not get a manual when i bought it 9 years ago. Please if you have the no how tel me, i would try but i am not going to screw something up. Thanks guys! Ride Red!
Old Dec 11, 1999 | 04:28 PM
JRM's Avatar
JRM
On a cold engine, with engine off loosen the lock nut (big one) and turn the clutch adjuster (small one) counterclockwise until you feel SLIGHT resistance. then turn it 1/4 turn clockwise. Now tighten the lock nut makeing sure the adjustor doenst move. Test ride and make sure everything is cool. One way is to shift into 1st and hold the shifter up. Then let the shifter down and the quad should just barley jump forward if at all. I can E-Mail you pages our of my manual if you want, as there are oil filter's behind the clutch cover
Joe
Old Dec 14, 1999 | 12:42 PM
200xtra's Avatar
YOUR CLUTCH IS GONE MY TRX125 HAD THE SAME PROBLEM TWICE FROM SPINNING IN THE SNOW YOU WOULD ADJUST IT AND AS SOON AS IT GOT HOT IT WOULD LOOSE POWER AND THAT MIGHT BE YOUR PROBLEM.
Old Dec 14, 1999 | 05:39 PM
RangerSX's Avatar
TRX200- the clutch is still there, it just slips (barely) when at high speeds.
Old Dec 15, 1999 | 12:00 AM
bigmanMH's Avatar
You need new friction plates in your clutch i had the same prob it would not slip exceep when in fith all the way in. This is your prob i no for sure
ghost civic
Jan 15, 2020 07:43 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
