BLASTER MISSING A PART?
Old Aug 26, 2002 | 10:21 PM
raptor8's Avatar
WAS JUST CLEANING MY BLASTER and noticed there's a hole on the passenger side of the carb that has threads, but nothing in it. LOOKS like there should be an idle speed screw in it. the rig seems to run fine, BUT i dont wanna fry a piston! Am i missing a brass noodle? help!
Old Aug 26, 2002 | 10:42 PM
blaster19's Avatar
It's fine. Nothin goes there that I know of. Mine has the exact same hole. I don't think nething goes there really.
Old Aug 26, 2002 | 11:44 PM
blaster425's Avatar
Yeah I noticed that on mine too. When I shined a light down the hole it looked like it was closed off and couldn't effect anything.
Old Aug 27, 2002 | 12:42 AM
raptor8's Avatar
COOL. thanks friends for the help. i was really excited there for a few as the rig is only two weeks old... see ya!
Old Aug 27, 2002 | 12:45 AM
warrior007's Avatar
pretty sure its so they can use the same carb on other quads and bikes that require two carbs they bolt them together. like the banshee?
Old Aug 27, 2002 | 11:19 AM
AlkyBurninX's Avatar
If it is what I think you are refering to, it is to hold the clamp to keep the carb cap from turning. The banshee uses the same carb, and the left side clamp is on the left, right is on the right.
The hole for the idle adjuster (blaster/banshee doesn't have an adjuster from factory) should not be tapped, and the end is cut at an angle. If you get a Motion Pro throttle kit to get rid of the clusterf@#k that is on top of the carb, you will need their idle adjuster kit. You will drill and tap this hold and install the adjuster screw.
Frisky2050
Apr 9, 2020 11:19 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
95wolv
Jul 21, 2015 12:25 PM
joeyupton
Jul 14, 2015 11:51 AM
