Still no front Brakes on Recon
Old Aug 29, 2002 | 08:41 AM
Maddog75's Avatar
I have adjusted and bled front brakes sill still lever goes all the back and no front brakes,rear brakes are great. maddog75
Old Aug 29, 2002 | 11:35 AM
95wolv's Avatar
Try cracking open the line right at the master cylinder,you may have a big bubble trapped high where it can't get pushed down to the wheel cylinder. If you have access to a syringe or something to push fluid with,try reverse bleeding.You put a hose on the bleeder and force fresh fluid from the cylinder to the master on the handle bar(empty the master first,or you will make a mess.) Air is hard to push down hill,so reversing the flow uphill will make sure it all comes out. If that fails,you may have a bad master cylinder,and will need a rebuild kit,just a couple of seals and springs,won't cost too much.
Old Aug 29, 2002 | 04:07 PM
Maddog75's Avatar
I will try reverse bleeding I have syringe made by EIS.
Thanks, 95Wolv.
Reactant
Mar 30, 2022 02:08 AM
timster911
Jul 13, 2015 01:57 PM
tporath
Jul 11, 2015 12:31 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
MNatv89
Jul 7, 2015 11:36 AM
