Warrior Question
Old Sep 2, 2002 | 01:23 PM
hondabigred's Avatar
I just purchased a 96 warrior and when I start it up it will idle perfectly but when you go to rev it up it will sometimes make a sputtering sound and stall. When it stall it makes an air sound. I have found no leaks in the airbox or headpipe. Also when you get going it will miss a little until its warmed up. I put in a new plug and it isnt the problem. Once the bike is running for 5 minutes it runs perfectly and will not have this problem. Also it takes it forever to warm up even on 80 degree days. Is this normal for warriors or what. Any suggestions on how to fix this would be greatly appreciated
96 Warrior
89 Mojave
84 Honda ATC200M
Old Sep 2, 2002 | 01:29 PM
WarriorMadness's Avatar
Mine used to do that I had some trash in the carb. Just removed it and cleaned it out. Now the only problem with mine is it smokes until its warmed up. Time for a rebuild.
Old Sep 2, 2002 | 05:33 PM
warrior350megamax's Avatar
I agree with warriormadness, it sounds like your carb needs a good cleaning, while your at it check your fuel filter also,
Patrick
Old Sep 2, 2002 | 10:18 PM
WarriorManiac's Avatar
hondabigred, mine did just as you describe before some of the mods I just did. either opening intake side (k&n filter) or the idle mixture adjustment after the jet change cleared it up for me.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
