Warrior Question
I just purchased a 96 warrior and when I start it up it will idle perfectly but when you go to rev it up it will sometimes make a sputtering sound and stall. When it stall it makes an air sound. I have found no leaks in the airbox or headpipe. Also when you get going it will miss a little until its warmed up. I put in a new plug and it isnt the problem. Once the bike is running for 5 minutes it runs perfectly and will not have this problem. Also it takes it forever to warm up even on 80 degree days. Is this normal for warriors or what. Any suggestions on how to fix this would be greatly appreciated
96 Warrior
89 Mojave
84 Honda ATC200M
96 Warrior
89 Mojave
84 Honda ATC200M
