Blaster Help
Old Sep 3, 2002 | 01:04 AM
Ward660R's Avatar
I built a Blaster, for a friend, out of a box. I can't figure out how the clutch cable goes. Can somebody help?
Old Sep 3, 2002 | 01:27 AM
yamblaster98's Avatar
hey i had the same prob a few months back. first off get the clutch put on the handlebar part first, make it loose as possible and then ruin it down to the engine, now the part it hooks on where it pulls the clutch pust back manuall so the clutch is enganged, now u literally have to pull the wire and "stretch" it so it gets on, then just make the touch ups and adjust the clutch and what not and get it in well. It took me hours of frustration but once i learned u have to somewhat strectch the wire you will be fine, i hope this helps.later.
Old Sep 3, 2002 | 01:35 AM
Ward660R's Avatar
Thanks for that but how does the cable run? If I came off the frame with the cable and went straight to the little arm it would be about 18" to long.
Does the arm stick to the outside or to the inside? Does it rotate to the front or the back when you pull the clutch lever?
Thanks again for the help I am in somewhat of a perdictament(sp?)
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
