Rear sprocket
Old Sep 3, 2002 | 01:08 AM
DesertBum's Avatar
I was thinking of reducing the rear sprocket in size. What do most of you do? Meaning, how many teeth do you reduce it to? How many is stock? My chain looks great, the indicater says its new, how do I tell if it is "o-ring" or "x-ring" or "whatever"? I will have to have the chain cut after right?
Ron
PS Its for a 250R ATC '82
Old Sep 3, 2002 | 02:08 AM
KNOWSALOT's Avatar
The Facility
Stock gearing is 13 on the front and a 44 on the rear.
Gearing selection will depend on exactly what type of riding you do.
Larger on the front OR smaller on the rear for more top end.
Smaller on the front OR larger on the rear for more acceleration.
An O-ring chain and X-ring chain have rubber o-rings between the rollers and side plates on the chain.
Cutting requirements depends on the situation. Order your chain a bit longer than you need to begin with. Cutting a chain isn't a big deal at all.
Old Sep 3, 2002 | 12:27 PM
DesertBum's Avatar
Since the chain shows new ill just keep it. Where do I get it cut at, if I need to? How many teeth should I reduce it by?
Old Sep 3, 2002 | 10:44 PM
KNOWSALOT's Avatar
The Facility
<< Gearing selection will depend on exactly what type of riding you do. >>
Any local machine shop or anyone with power tools can cut your chain. Your dealer can also do this with a chain breaker, which is also available to you from most mail order companies.
Old Sep 9, 2002 | 10:12 PM
DesertBum's Avatar
So I have a 3:38 ratio? Is that anything like my rear`end of my suburban? If I go to a 40 say (in the rear) that would be a 3:07? OR should I go with a 36, which is a 2:76? Which do they make and where do I get them from??
Ron
Old Sep 9, 2002 | 10:39 PM
reconbasher's Avatar
just try a 14/42 ratio. it will make it a 3.00 gearing thats in between what you just posted
Old Sep 9, 2002 | 11:36 PM
DesertBum's Avatar
Where do I get one at?
Old Sep 10, 2002 | 08:18 PM
at any honda dealer or you might try www.rockymountainatv.com or www.denniskirk.com
Old Sep 10, 2002 | 11:41 PM
atc86r's Avatar
i use bench grinder to cut my chain. just grind the pin and tap out. no big deal real easy.
Old Oct 27, 2002 | 01:01 AM
rideitlikeustoleit's Avatar
Default Rear sprocket
You guys changing front and rear sprokets are just cancelling youself out. Why no just keep your case saver on leave the front 13T alone and change rear to 40T. This gives you a 3.07 Gear ratio(or 39T on rear makes a 3.00 gear ratio). With changing the front to 14T and removing case saver and changing rear to 42T you end up with a 3.00 gear ratio. Why buy two sprokets instead of one. May need to take a link out of your chain though. Still its gotta be cheaper.
Can you guys think of any downsides to leaving 13T on front and 40T(or 39T) on rear rather than 14T front and 42T rear????? Pretty much the same ratio.......
mywifesquad
8
Sep 21, 2015 08:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
