Raptor craps out doing wheelies,,,Float bowl setting?
Yes, I definitely suggest checking the float levels in the carbs. I have just recently had this problem, after a rebuild and more jetting, mine were off!
It is easy to bump them while the carbs are apart too. I remember lying my carbs down on the bike while doing something away from the bike, I'm assuming now that I had them lying on the right carb's float tab while the bowl was off! DUH!! Because when I went back in there to check them, the right carb's float was off quite a bit! I set both of mine 1 mm below the spec of 13mm, they are now set at 12mm.
This is where I would start looking for a cure! Good luck.
"TOID"
"TOID"
