Raptor problems
Old Sep 4, 2002 | 05:48 PM
SPAR's Avatar
I think the valves need adjusted, but i'm not sure. It will start with the choke on, but doesn't like to run with it off. When you give it gas it's not very responsive. And if you give it too much gas it backfires real bad and blows the carb boots off and dies. What do you guys think?[img]i/expressions/face-icon-small-confused.gif[/img]
EDIT: this thing is totally stock, and its been awhile since the valves have been messed with.
Old Sep 4, 2002 | 06:45 PM
velocityraptor's Avatar
Sounds to me like your running lean and are compensating for it by running it with the choke on in turn making it run rich< I've come to find out that the 01 raptors that are running rich tend to blow the boots of the carbs more than one that has proper jetting.
Remember just because it's stock dosen't mean the jetting is right.
Hope this helps
Old Sep 4, 2002 | 08:11 PM
RaptorRider660R's Avatar
Check the carb boots for a possible rip, I had to replace mine they blew off and then I tightened them too much and tore them.
Nocando
Old Sep 4, 2002 | 09:05 PM
warrior007's Avatar
I had the same sputtering problem with mine. It would start fine when cold but run a little rough until I got it warmed up (100 yards) after that it would die when given gas and would run a little better with some choke. I put on a new plug and it fixed it. First time I ever had a plug go bad prematurely on a 4 stroke.
(parking brake sensor has long been gone on mine)
Old Sep 5, 2002 | 12:18 AM
SPAR's Avatar
Thanks for the replies I will check this stuff out.[img]i/expressions/face-icon-small-cool.gif[/img]
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
