HELP!!! how do I set timming on my quad?
Old Sep 10, 2002 | 01:47 AM
dwood1971's Avatar
I have 1996 honda trx 300 4x4 and I need to know how to set the timming? Could someone please help me ?
Old Sep 10, 2002 | 05:00 PM
AlkyBurninX's Avatar
Ignition timing is non adjustable. As for valve (cam) timing, simply line up the mark (TDC) on the flywheel with the pointer. Line the line on the timing sprocket with the notch on the rocker cover.
Old Sep 11, 2002 | 07:26 PM
dwood1971's Avatar
Thanks For the reply. but I need a little better detailed info on how this is do . Thanks Dan
Old Sep 12, 2002 | 06:52 PM
The best advice is simply purchase a manual. Sometimes the pictures are better than verbal. I haven't actually worked on a 300 honda, but most hondas are the same.
To start, find Top Dead Center (TDC) or (T) on the flywheel. Line it up with the pointer, notch, or mark on the flywheel cover. The cam will either have one line, three lines, an arrow, a dot, or some kind marking. If you can post what you have, it would help. If it has three lines (like a lot of hondas) one will be straight up, and the two that are directly across from each other will be lined up with the head/rocker cover mating surface. The cam will be installed with the lobes down.
If none of this helps, tell me what you are looking at. Like I say, every model of engine can be different.
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
